configure stpd hellotime
configure stpd stpd_name hellotime seconds
Description
Specifies the time delay (in seconds) between the transmission of BPDUs from this STPD when it is the root bridge.
Syntax Description
stpd_name Specifies an STPD name on the switch.
seconds Specifies the hello time in seconds. The default is 2 seconds, and the range is 1 to 10 seconds.
Default
The default hello time is 2 seconds.
Usage Guidelines
If your STPD has the same name as another component, for example a VLAN, we recommend that you specify the identifying keyword as well as the name. If your STPD has a name unique only to that STPD, the keyword stpd is optional.
In an MSTP environment, configure the hello timer only on the CIST, not on the MSTIs.
You should not configure any STP parameters unless you have considerable knowledge and experience with STP. The default STP parameters are adequate for most networks.
The range for the seconds parameter is 1 through 10 seconds.
The following command sets the time delay from STPD1 to 10 seconds:
configure stpd stpd1 hellotime 10
Platform Availability
